Hey y’all, I’m a lurker here on this forum but now need some assistance
I’ve come across a Dell T5810 with:
Intel Xeon E5-1650v3
Nvidia Quadra M4000
Few TB’s
I want to build a nas for a home theater,
And I wanna make a separate device for servers to practice IT and cybersecurity skills. Mainly- Docker, Ansible, SIEM, log ingestion, full purple teaming lab using sigma/security onion.
What type of components should I look for? Should I keep the current parts and build a DIY nas then buy a mini pc for everything else?
This is if you want to put it all in the same system with 2TB of mirrored storage. Your system has one, maybe two selling points, and that is ECC RAM (which matters for some use cases, though you rarely find those in a home setting) and maybe support for IPMI. ECC is still cheaper and more reliable on AM4, though AM5 is slowly turning that around.
As always, I am a fan of the Asustor Flashstor for home labbers with modest storage requirements (< 24 TB). The Flashstor 6 which sports six m.2 bays and dual 2.5GbE ports, can be had for $450, and decent 2TB drives cost about $100 as you saw in the example build above. I would not go nuts on decking out a full 6x2TB system as a 3x4TB system makes a ton more sense for pretty much the same money. However, a starter kit with a Flashstor 6 and a mirrored 2TB setup, costs only ~$650.
If you thus build the above build plus a Flashstor, that is just about within your budget and you have the best of both worlds running on a fraction of the power the Dell T5810 runs on.
This assumes you do have modest storage needs though, and are fine with not having ECC memory.
Do u have experience with linux ?
Do u also want to experiment with the managment modules in server. ?
Otherwise Do u have old hardware, just start with that. ?
I have a n100 board doing a lot on that a couple webservers, mysql, and some samba for the home network And those boards are not expensive. But i’m not going to virtualize on that machine. the machine simply don’t have enough resources for that to be fun. But it is also not power hungry. i want it to be on 24/7 so i rather have a system then can do that on low power. then puting a powerfull procesor in it for the 10 minute’s i use that in a week.
The computer i used before that under my tv is now doing a windows server. totaly useless by the way at home but good for experimenting. Dat mainboard i think is about 10 year old now procesor to it might even be more.
Where are you going to place it ?
If you are going to have it mounted in a own room and connect to it trough a network. a actual server is fun. A server in your study. Now, that they can be loud is a understatement. If you want it in your study. mayebe a old treadripper.
What kind of network are u using ?
On 1gbe most raids and ssd’s can get that saturated. but if you go to 10gbe You want quicker storage, and then pci expres 3 might be a problem .
Yes,
Right now now I’m dual-booting EndeavorOS running hyprland with Windows.
It’ll be next to my desk most likely, and I will need virtualization.
Old tech is nice but I’m looking for a good middle ground. Something not too old since it will be next to me at an deskand I don’t want it to be too loud.
I think most parts is also available via ameridroid if you prefer a us based reseller.
I know that it’ll only do 1x PCIe on NVMEs but given that it’s a NAS and it’s 2.5Gbe per port (Intel NICs) you’ll be more than fine even if would use link aggregation. Run whatever OS you prefer, I would personally recommend FreeBSD and ZFS but that’s me.
The only downside is that it’s not ECC capable but given the very good bang for the buck I think it’s still a very good tradeoff and you’ll have a hard time finding anything “better” at the same price point.
As for the “server”
If you want ECC look at a AM5 platform, it doesn’t need to be all the beefy otherwise I’d honest look for a regular desktop/tower from Lenovo’s Outlet-store.
