Need help - building FTP Server
Hello all!
This is my first post on the forums! I am building a FTP for all my files (obviously) and I was wondering of anybody had suggestions for parts. And by parts I mean cpu, motherboard, and any other random bits that might make my server awesome!
I am willing to spend around $300-400
I live in the USA
I don't have any parts at the moment except a keyboard and mouse I found lying around as well as a monitor
I don't want to overclock
No custom cooling will be necessary
I will be using Linux because it's the best.
Any advice that can be offered will be taken with an open mind and will be much appreciated! Thanks!
Well, you may be better off with a NAS rather than an FTB server, look at something like FreeNAS, it's a FreeBSD Distro (Unix/Linux). There multiple file distribution options including but not limited to FTP RSYNC AFB CIFS and NFS. As for parts you really don't need much hardware, though if you are going for redundant storage (Such as RAID-Z) you will want an amount of ram equal in ratio to 1GB:1TB of storage (8TB storage pool 8GB of RAM) For $400 you wont be getting much space. Let me see what I can do for you.
Well it seems at that price range unless you are able to use an old PC as server you may be better off getting something off the shelf. Something like this should be an option and it can run with 1 disk as backup and can run as an FTP server as requested. http://www.newegg.com/Product/Product.aspx?Item=N82E16822165535
Thanks for the help! I'll probably purchase one of those instead of building a server myself. I really appreciate then help
FreeNAS is really easy to install and use, it also allows you almost complete control from the browser link. I would still recommend building such a system yourself, as it is quite enjoyable and you can get a significantly more powerful system for the money.
http://pcpartpicker.com/p/22ffN
Try this one.
Thanks for all the help!
