So I am building my first gaming rig and need help so that I get the best rig for my money. I have a budget of $500-600 and I only need a case, CPU, GPU, motherboard, RAM and power supply. I am looking for parts that are avaliable in Australia or that are avaliable to Australians. I am also looking into overclocking my CPU so feel free to put any overclocked parts and recommended heatsinks in your recommended build. I do not care whever the build is AMD or Intel, I would like to see both AMD and Intel options.
I used pcpartpicker.com to create a build, then changed it from there. I'm from Aus too, and haven't built my first gaming rig yet, but I found that on here, it's more helpful to start with a rough idea of what you want, then let the community have their input on what to change.
Edit: In the list on pcpartpicker.com there are only Intel CPUs.
Edit #2: Never mind the original Edit. I found the button that shows all the pretty CPUs.
msy is a good computer store in Australia they have mostly all the parts for a computer you will need and there really cheap as well and there in most places in Australia.
This is off topic but I think you should consider ordering from there. =)
