Hi All,
As the title of this thread might suggest I need help in building my first gaming PC.
I have a budget of around £750 - £800 (yes, I'm in England so I need prices in GBP please!) and I will be using the PC for lots of gaming now and in the future but also I will be doing lots of coding in C#, Java, C++ and I will be using the Direct X graphics library, but I probably won't be rendering or creating 3D models etc.
I have pretty much decided on the AMD FX-8350 (around £150 - £200) as my processor however when it comes to GPUs and motherboards I don't really know where to start.
I would be happy to overclock the hardware to an extent if that would make much of a difference as long as heat and stuff stays stable.
Would anyone be able to suggest GPUs, motherboards, power supplies, RAM, a case and probably a monitor that would allow me to play the latest games and those that will be coming out in the future at reasonable FPS at medium-high settings, while staying within my budget.
Also, I wouldn't like to hear that X is better than Y just because it is, I want facts and figures, benchmarks etc to back up what your saying.
This is my first PC build and although I am well versed with computer software my hardware knowledge is severely limited. For that reason if you wish to use technical jargon like PCI-E, SLI, CUDA cores and stuff like that please clarify what they mean.
As a starting point two videos I have seen from Tek Syndicate introduced me to
- Asus GeForce GTX 760 - GPU
- P8Z77-V Pro - motherboard
Would these me good for me?
A few things to consider are
- Will the power supply be able to provide for all the other parts? (in terms of wattage)
- Will the motherboard, GPU and other stuff fit in the case?
- Does the monitor support 720p (I don't particularly mind if I don't get to play in 1080p or 1440p)
Sorry about the VERY long post and thanks in advance for any help you can give me,
Matt.
