I assume this hdd is from a previous system, so chances are you'll have to change the sata mode to ide or ahci, whatever the opposite is of what is there.
My advice would be to get what you want of the HDD, then start with a fresh install otherwise there will be loads of old junk drivers etc sitting around.
Sweet thanks I'll try that. How would I go about changing the HDD to ide or ahci ?? The motherboard previously was a gigabyte and am currently on a Asus maximus impact! :) ... where in the bios can the HDD settings be changed? :)
Woohoo, it worked. Thanks man! :) ... I needed to change it from Achi to IDE :) !!!
Can't find my windows 7 install disc.. sad times.
I do have an optical drive, but it's not connected and since am using a prodigy case, GTX 680 classified, h100i... there is no chance I can connect the optical drive up :(
So it is possible to put the Asus Disc I got with the mobo onto a USB like windows 7 to install all the drivers when I do a fresh install ??
