Need Help: Baldur's Gate 1 Install Error - Mo
I recently bought Baldur's Gate 1 (used), and just received it today. I got the manual, quick reference guide, map, and 5-disc sleeve, everything but the box. Everything is in great condition, and I mean really great condition. But, I noticed the first disc had some scratching. Not too bad looking, but I thought it might be fine. I've ran games with worse scratching than that, after all. Well, I start installation, and I get this:
[quote]an error occured during the move data process -106
Component: Program Files
File Group: MinimumData
File: CHAANIM.bif[/quote]
I'm almost certain it's a disc problem, but perhaps one of you have had a similar problem that wasn't the disc? I've tried to install several times; The minimum, the recommended, the maximum. I restarted the computer several times to try again, and even booted in safe mode to try. Cleaned the disc with a spray of water and a microfiber cloth, making sure to wipe from the middle out, a few times. Despite my best efforts, the error persists. Damn shame too, everything else is beautiful.
All of my system requirements check out, and I have been able to run other Infinity Engine games such as Baldur's Gate II and Icewind Dale without issue. All drivers for my system are up-to-date.
OS: Windows XP SP3
System: Dell Latitude D600 (laptop)
HDD: 30GB 5400RPM
CPU: Intel Pentium M 1.6GHz
GPU: Mobility Radeon 9000 32MB DirectX 8.1 OpenGL 1.4
RAM: 1.25GB @ 1.2GHz
DVD / CD ROM Drive: HL-DT-ST RW/DVD GCC-4243N
Can anyone help me out or are you guys thinking this is a disc problem like me?
i remember i had to do something with the rezolution + windowed mode.... im not entirely sure... its been a while since i have played baldurs gate.... (actually... thinking about it, i might be thinking about icewind dale 1)...
anyway... why not torrent the disks, and use thoes to install... and use your cd key.
what he said^^
but also I've had a few problems trying to install baldurs gate 1 and 2 on Vista or windows 7 that I dont really remember how I fixed
