Need help/advice
I posted earlier about upgrading my PC, didn't really receive any reply's so i'ma go ahead and try again.
So Christmas is coming and i'm looking to upgrade my entry level gaming PC. My current rig is:
  • Gigabyte GA-B75M-D3V motherboard
  • EVGA GTX 650
  • 8gigs of ram
  • 500w power supply
  • i-3 3220 processor
I want to get a GTX 760 graphics card but i'm not sure if my parts are compatible or what not, i'm scared that my i-3 will bottleneck the hell out of the GTX 760. Any suggestions and or help would be great!
What's your budget for the upgrade? And is it only the graphics card you want to upgrade or are you willing to go further?
My budget is around 200-300 dollars, but i only want to upgrade on component.
Really all i want to know is if a GTX 760 would be a good upgrade, i don't really know because my processor is pretty garbage but then again so is my graphics card.
Alright. Well, your parts are compatible no problem with the 760, just make sure your power supply has the correct PCI-E cables for the card. You may not get balls to the wall performance with it in conjunction with an i3, but it will definitely work. Depending on the types of games you want to play, it shouldn't be too much of a 'bottleneck'.
thanks man.
Dont worry about the bottleneck.. It is a good upgrade, and dont let anyone tell you any different! The i3 and 760 isnt the best optimized pair, but it is the correct choice! Get the 760 now, and you can always upgrade the CPU later if you choose. But its really not necessary.Enjoy your performance increase!
PS, when it come to your next CPU upgrade, waiting for the next platform would probably be in your best interest if your PC gaming budget isnt very high.  Try to save some dollars, and pick up an entry level quad core CPU with a decent mobo for your next upgrade. During the time of the next platform release the 760 will still be a worthy GPU for optimal performance.
+1
