Need Help - $600 Server Build
Hey guys so I have been using one of my old laptops as a Linux server and it is starting to worry me that it is going to light on fire lol. I am looking to build a server for around $600. The server will be an FTP, a Minecraft server, as well as any other random thing I can think of.
I don't have any parts at the moment so I am looking for some advice on what to get. I would like to have some noise reduction aspects to the server if possible. Hopefully the community can help me here! Thanks!
- Zachary
Okay. So for Minecraft high single core processing speed is the most desired thing.
http://pcpartpicker.com/p/2BMoN
So my reasoning.
AMD FX-6300, it's a really good chip for the money has a good throughput and is much cheaper than the Intel equivalent. This chip EASILY clocks to 4GHz, all you need to do is change the multiplier. (literally) It doesn't require any more voltage than that of the stock clock.
The board, yes the VRMs do run a little warmer than that of any other 990FX board. Although it is the cheapest (excluding the ASRock board (I've only ever had bad luck with ASRock so I avoid them)). You only really need to worry about the VRMs if your using an OC'd FX-8xxx chip though.
Memory, I chose two 8GB modules to achieve 16GB so that it leaves room for future expansion upto 32GB if required. Vengance is good memory, although if you can find something of similar performance/specs for cheaper, go with that.
Minecraft also loves disk access when there are multiple users. That's why this build has an SSD, for a linux server you only need a 60GB SSD. There's also a 1TB disk, you can use that for backup of the server and any other things you wish to back up. If you already have a method for backup, then you can drop the HDD, save the money or get a larger SSD.
The video card is literally just to give you a VGA out as the 990FX boards do not have one in the Chipset.
Case....it was cheap. :P
I can look into a similar build with Intel if you would like.
here would be a pretty good choice: http://pcpartpicker.com/p/2BMeg
8 core processor, 16 GB of nice ram, 2 TB HDD and just a simple video card for you getting a video output, all in a nice silence optimized fractal desing define R4
*edit* haha sorry it was like 4am and I only read the title. Carry on ~
Did you just? Did you really just recommend a dual core and 4gb's of ram for a game server? You need lots of ram and lots of core's for a game server.
I'd go this direction. 16gb's of ram, a small ssd plus a 1tb hdd and a solid 8 core processor. http://pcpartpicker.com/p/2BZhc
Don't worry dude there was no way I was going to go with that build. I need help putting the parts together but not so much that I have no idea what I'm doing. I do appreciate him giving me his point of view on what I should put into my server, but it won't be what I'll be putting into my server.
I think you should re-read the question here... hes looking for a server for games, not a NAS.
However if you where going a NAS with no video card why not go for a M-ITX mobo and Fractal Design Node 304, its not only lots smaller than a mid tower, its better built than there Core series and still packs 6 3.5" or 2.5" HDD\SSD's if you use a short graphics card or non at all). It also comes with all the fans you need (silent series ones on inbuilt fan controller at that). It also can handle large CPU coolers and full size graphics cards and even 120mm rads should you want to re-purpose it to a portable gaming or render box in future. But ultimately its main advantage is its small, decent looking and well made while still fitting more storage than you'll normally need.
