Hi i'm making this post because i cant make up my mind on what GPU to buy i was wondering if anyone could recommend a good GPU to buy i am upgrading from a gtx570. Preferably a Nvidia card. also would like to stick a water block on it later.
gtx 770 reference design would be best for a waterblock.
Funny thing about Kepler, i can OC the hell out of it without waterblock. It doesn't rly throttle or anything. On my GTX 770 i did +150 on the core and +250 on the memory. Anything past that it won't let me, even when i set the max temp to 95c... I've come across this kind of issue with a few other Keplers, so it's probably better to just buy a 780 over a 770 with a waterblock.
Thanks for all the reply guys!! i decided to go with this one.
because i looked on EKWB and they had a WB for it and that's what brand i had on my 570 i just cant watercool right now because my pump broke.
