I'm a first timer and I'm just looking to make sure that everything I've picked out is compatable and fits and all that jazz. Really just making sure there aren't any fatal errors. The parts I picked out are:
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible with Intel ...
this is a much better system for 800 dollars well its a little over budget it 832 all prices from newegg cant be bother linking it but you just search up the items
Ok my friend, I've asked this question multiple times in diffrent places because I don't wanna screw anything up. I was told that I should get the 7850 because it's better then the GTX 650 so I changed it. I reposted the update and was told to switch back. It's been back and forth. Right now I just wanted to know if when I put it together that it would work. I've gotten my answer so thank you but I don't need any more suggestions.
Plus every fact sheet I could find says GeForce over Radion equivalents.
