Here is the build that I am planning on making by the end of May. It will be used for gaming and game design primarily. I am making this build so I have a good solid computer to last me through college thats also gonna be able to do what I need it to. I don't plan on doing any overclocking with this at all. I'm just wondering what others think about this setup. I'll probably be buying these parts as I get the money, hopefully as cheaply as I can get them. I know new stuff will be out by May but I think this setup will still be a solid one and hopefully the parts will drop in price by then. I am thinking about going with a different power supply because I'm not really sure if I need a 850W, I'm also deliberating on whether or not to get and SSD. I would love some input, thanks.
going to be brutally honnest here, that is absolutly terrible, for one you spent more money on your motherboard than you did GPU, and your case is more expensive than your CPU THE CORE OF YOUR COMPUTER. the FX qaud core isn't really a qaud core its a dual core with amd's "answer to hyper threading". even though its 80+ I still wouldn't trust that brand of PSUs
GPU comparison
http://www.anandtech.com/bench/Product/536?vs=647
CPU comparison, this is the 8 core FX against the Sandybridge version of the CPU I choose and its STILL losing (bulldozer is that bad really)
Theres over a hundred dollar difference between the build I've been working on and the one you have suggested, I honestly have no money at the moment and I'm going to be scrounging for money to get a new PC. My budget may end up (hopefully) being around $750
I'm wanting to stick with a full ATX so I have plenty of room for upgrading, plus I'm wanting to stick with AMD. I'll revise my build and post it later.
agreed there are always like 2 day deals on newegg, come back here a day or two before you buy everything, chances are the list then will be even better than they are now, and you'll want to buy everything at once, it would suck if you got a DOA part and didn't know it and the warrenty was over
I agree, the "I'm going to upgrade it later" mentaility never works out even when you usally have the funds. Build a well balenced system from the start and you won't have to upgrade for a while.
Also I'm more of an AMD guy, though in this current market FX is a waste, and I assume Piledriver will be the around the same. Go for a Intel i3, or i5. You'll be a lot happier in the end. If Piledriver turns out to be a competeing platform with SB and IB then I would say go for AMD but right now it's kind of bad.
