Need Case Suggestions
Hello
I am building a high end multipurpose computer. I need some ideas on what to get.
What i am mainly look for:
1. Price less then $160 (aus). Could go higher if needed
2. Side window
3. No optical bay door
Thanks
Most people suggest Fractal:
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_1055&products_id=22643
Corsair cases are good. C70:
http://au.pcpartpicker.com/part/corsair-case-cc9011016ww
Yep the Fractal R4 is nice i kind like the corsair 750D too (its allso better equipped for closed loop coolers and water cooling if you whanted that)
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_547&products_id=19094
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_547&products_id=18478
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_547&products_id=25178
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_547&products_id=21682
I was considering the Aerocool Xpredator X3 Avenger High Mid Tower that you suggested but it doesnt have a reset button. Would that be a problem?
I actually have no idea sorry, I guess it depends whether or not you would use one.
