Stevejs
1
Building a system and I have everything but a case, I need something to fit this
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106190
The radiator with fars attached is is 270x120x53.3
I dont need a full sized case but if that's all it'll fit in I'll take it
Ive been looking at these
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139018 (cosair mid size)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133194&RandomID=3032468195363420131024153802 (thermaltake full)
The case is the last component i need and I'm really looking forward to getting started with this build.
Thanks in advance,
Steve
deejeta
2
200r is a no go, not enough room between roof and top of motherboard, and that Thermaltake case should be killed with fire (terrible, terrible case)
There are some cheap cases that will support your AIO cooler;
CM 690 II http://www.newegg.com/Product/Product.aspx?Item=N82E16811119259
NZXT 410 http://www.newegg.com/Product/Product.aspx?Item=N82E16811146085 --- excellent case
Antec GX700 http://www.newegg.com/Product/Product.aspx?Item=1N8-001K-00002
Fractal R4 http://www.newegg.com/Product/Product.aspx?Item=N82E16811352021 - nice case as well.
Hope this helps.
Phantoms are great, +1 for that
