Need Advice!
Hi, I'm Zach. I've never built a PC before and I'm giving it a try now, any way I've got all the parts together for the build. I'll be receiving my A-10 7850k today,but the motherboard requires a bios/driver update for the cpu. (asus a88xm-plus/csm). The question I want to ask is will I be able to flash the bios with the 7850k installed? Or will I have to spend more money buying an older richland part in order to preform the update?
P.S. If i do have to buy a richland part for the update (like a 49.99 A-4) will it be compatible with the 2400mhz memory I have? (Team vulcan 2x4gb ddr3)
For my A10 7850k build (I have the EXACT same parts as you), I used an A4 APU to get the BIOS flashed. I didn't even think about trying the A10 first, but I also had an A4 in my shop. As far as the RAM goes, the motherboard automaticly had my RAM set at 1333 at first. I had to manually overclock to get to 2400. This has been true with any build that I have done. For compatibility reasons, I think the motherboard always goes with low frequency to make sure the user can get a successful POST.
Thanks, man but In my research the RAM thing has to do with the XMP/AMP profiles, starts off low and you just select the profile, but what you said about ensuring POST makes a lot of sense to me.
I think XMP is for Intel.  I'm not to sure with AMD, but I think you might need to manually OC it on AMD.
XMP can be used on AMD platforms, at least my FM2+ board is compatible, so you should be able to use XMP as long as the RAM supports XMP
Yeah, XMP is for Intel, AMP is for AMD. The board I bought has a feature that closely matches the XMP profile
