Need Advice
Hi all I have recently built my 1st custom gaming pc and was wondering if I had to add additional fans (I may be planning on overclocking). Note: pls treat me as a newbie about fans.
I have a NZXT Phantom 410 case with 3 stock case fans, 140mm at the top and 120mm on the back and front. I need advice on what fans to get. My CPU cooler is a Phanteks PH-TC12dx and the orientation its in is blowing air up top the case  (not the usall to the back of the case).
My problem now is what fans should I get, should I put 2 140mm on the front for more intake or 2 120mm should be fine??Also does a side fan needed?? (LED fans btw)
thanks,
atobe
I have the 410 and mine cannot fit 2 140mm fans in the front. i would suggest noctua NF-F12 or if you want a little cheaper go for some fractal design fans.
Noctua
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608026
Fractal design fan.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835352006
Corsair AirFlow quiet edition fans are the shit. I'm gonna pick up two more 120s and replace the stock ones on my phanteks.
Thank you, I will keep them in mind. Do you think I would need a side fan?? Any suggestions with LED fans??
Populating all possible fan mounts is the most optimal configuration possible. It helps with dust, thermals, and other things. You do not need to populate all fans, however.
As for LED fans, Silverstone Air Penetrators are a decent 120mm option. They have a good amount of static pressure and air flow. Good for radiators.
LED fans kind of suck in general. I would suggest normal fans and then getting a bitfenix alchemy strip.
Well i have a side fan a it dose cool the gpu abit better because it has its own air source. Only like between 5 degrees celcius difference with side fan but it is a good idea.
I don't know what colour you want so i will just post a link for many fans.
Xigmatek
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233102
Nzxt
http://www.newegg.com/Product/Product.aspx?Item=N82E16835146016
courgar
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553010
Not sure about these fans haven't heard much about them but it would be good to search around before you buy any product.
