Return to Level1Techs.com
Need Advice On A New Monitor
#1
Hello all,
I'm sure this has been asked a lot of times now, I'm looking to buy a new monitor to replace my two 24 inch monitors with my current setup i have to have one monitor in Portrait mode and the other in Landscape mode with the Portrait monitor i finding that my productivity have completely fallen off so i would like to go back to a single monitor setup. The Portrait monitor is really annoying me also i use a Monitor stand
I have been looking at some 32 inch monitors and a 29 inch Ultrawide so my question is should i buy a 32 inch or buy the 29 inch Ultrawide main use will be for gaming but i do watch a lot of YouTube & Twitch, I do like on the LG monitors that they have Screen split
My budget is no higher than $450 Australian, I understand in that price range the choices are not much or is there like a third party Software where you have split the screens i'm not really sure i don't know that much about monitors.
Thanks
#2
https://www.amazon.com/gp/aw/d/B000FOGT9W/ref=mp_s_a_1_3?ie=UTF8&qid=1500192978&sr=8-3&pi=AC_SX236_SY340_FMwebp_QL65&keywords=crt+monitor&dpPl=1&dpID=41K%2BN%2Bq5qVL&ref=plSrch
#3
Why tf is that 350?
#4
1080p CRT :U
Because I like CRT's.
#5
@tkoham
Ah no thank you why would i use a monitor that's smaller then the ones i'm using now and plus it's 12 years old monitor seems like you didn't even read what i typed i said i'm using a monitor stand.
#6
He is being half a troll.
CRT monitors are still king for competitive CS:Go players because they have very low input lag and motion blur. Most LCD and LED monitors tend to lag behind a few frames compared to CRTs.
Anyways. I am thinking you might be happy with something like this
https://au.pcpartpicker.com/product/WX7CmG/asus-va32aq-315-2560x1440-60hz-monitor-va32aq
You get a slightly higher resolution at your 32 inches.
#7
@Tjj226_Angel
Yeah i understand that CRT monitors are still king, The ASUS monitor no one local to me has it in stock plus it's $30 over budget and plus i would have to pay at least another $30 for shipping. So i really can't afford it there is AOC & ViewSonic monitors.
#8
This is well underbudget and been a great monitor for me, you can OC to 100hz as well with no issues.
https://m.newegg.com/products/9SIA4JH1GM6846?ignorebbr=true&nm_mc=KNC-GoogleMKP-Mobile&cm_mmc=KNC-GoogleMKP-Mobile-_-pla-_-Monitors+-+LCD+Flat+Panel-_-9SIA4JH1GM6846&gclid=CLDryoC3j9UCFUgjgQodF-wGXQ&gclsrc=aw.ds
#9
Yeah, I have no experience with AOC, so I can't recommend them in good faith.
#10
@_hill
That monitor is not really what i'm looking for it's only a 27 inch and plus i can't buy anything from Newegg cause of the shipping.
@Tjj226_Angel
No problem i don't think i will get the AOC cause it's doesn't have the Vesa Mount where the ViewSonic does.
I think i would prefer getting a 1440p monitor so looks like i might be getting the ViewSonic.
