I'm looking for a new headset, my old Roccat kave finally died after a long battle and am now in the market for a new one, im looking for 5.1/7.1 and my budget isn't the high (£60/$95ish) and would appreciate some suggestions, i was initially looking at a Plantronics Gamecom 780 USB Headset but if there's a better better headset for bit more id rather pay for quality. Also, is there a big difference between using the headset 3.5mm jacks over a USB?
Thanks in advance
The 780s are pretty good for the price the only thing is they can be muddy in the lower range. Are you using these for gaming or gaming and....
I wouldn't get caught up in the 5.1./7.1 Surround sound, it's all digitally processed anyways so it's very inaccurate. I have found that (this is honestly just my opinion through personal experience) I prefer Higher quality headphones without virtual sound.
I would also suggest the Corsair Vengeance 1500v2 USB, or the Corsair Vengeance 1400(it's a Dual 3.5mm).
mmm thanks alot, ill check them out, almost double the price so im hoping its worth it :D
