AMD FX-8350 AMD 7950 Crossfire 12GB RAM ASUS M5A99X EVO Bunch of HDD/SSDs
I'm curious what would be a good single GPU that would be as good or better than crossfire 7950s. I'm getting a lot of bugs and frame skipping with crossfire (both cards work 100%) and just want to move back to a single card. Suggestions?
Far as the high end goes, the R9 nano with the recent price drops is probably the best buy, especially if you want to save money with a free-sync display vs a G-sync display, however a 980ti once Overclocked, will beat it out by a fair bit at additional cost for the card itself.
which resolution are you aiming to play? Edit: ah i see 1440p.
R9-390 or R9-Fury might be a nice step up. If you could hold out, and wait, then i would recommend that. Nvidia and AMD will most likely going to release some new gpu´s this year.
