Hi (my first post in this forum),
my current PC I’m using for work as a C++ software developer is over 4 years old. Its time to buy a new one. I like to go with a 12 Core Ryzen 5000. My main problem with it, selection the right MB and the more difficult issue is the GPU.
SW to run:
- Linux: Manjaro
- CLion IDE (java)
- clang and gcc
- Docker (at least 3 container with the target build environment for x86_64 and aarch64)
MB requirements:
- 2 x M.2 PCIe NVMe slots (1 slot would work too) Would be nice if this was a PCIe 4 slot, not sure this will make a big difference.
- The PC might be running 24/7, so a solid MB would be needed.
GPU:
- I don’t need a lot of 3D graphic, at the moment an integrated Intel GPU works fine,
- 2 identical monitors (LG 24") with display port must be possible.
Parts I selected so far:
- Power supply 550W Super Flower (I use them in private PC’s)
- 32GByte RAM (Crusual Ballistix DDR4 3200 16)
- Samsung NVMe 1T 980 pro PCIe 4 (already ordered)
- Noctua CPU cooler NHU14S
- A case from Fractal Design, the case fans will be replaced by some from Noctua.
Thanks
PS.
I’m from germany.
