- Budget. How much are you willing to spend?
- $500
- Where do you live (what country), and what currency do you use?
- California, US. USD
- -Is there a retailer you prefer?
- Any retailer off PCPartPicker is fine :)
- Do you need or already have peripherals? (this can add to costs) Already have monitor and keyboard/mouse
- What will you be using your future computer for? Gaming? Rendering? Mix of both? Or is this a home media PC? Primarily web browsing, email and Youtube.
- Do you overclock or want to get into overclocking? Nope.
- Do you plan on going for custom watercooling now, or in the future? No.
- OS. Do you need a new one? Yes I need an OS.
- I apologize for the bad formatting D:
Just buy a 300 dollar laptop from bestbuy.
You could look into getting a nuc. That might be a good option.
You can buy pretty much anything and it will be good enough
This is probably overkill http://pcpartpicker.com/p/2H9PB
http://pcpartpicker.com/p/2H9T5
$510 a touch over but plenty of room to upgrade
ps pulling the cd/dvd drive out of the old pc will bring it right to $500
Any suggestions above would do perfectly fine.
