Need a unique build
I want the coolest build ever, that is not water cooled. Colors don't matter except don't go crazy.
Budget is $2000 (CANNOT GO OVER)
I'll be gaming and video editing on it at 4K.
$2k for the build?
Or do you also need peripherals?
I have a keyboard and mouse and monitor so just the build.
Here's what i'd do if i had $2000 bucks
http://pcpartpicker.com/p/Fmfb99
as for why there is much storage,
the 120GIB is for your OS (Whatever you want Windows or Linux)
500GiB SSD is for your editing files
2TB is for your storage (games, other files and or videos)
this is what i came up with, should be realy good for you needs.
maybe adding a bit more storage if you like to.
About the gpu i choosed for a 980Ti,
But you could ofc also look for a R9-Fury, and save bit of money if you like to.
http://pcpartpicker.com/p/gCpcnQ
I'm building an editing PC as well. Just a Tipp: The Timeline in Premier with 4k Video sucks when you store your footage on a Hard drive (I don't know about WD Blacks, just about blues and greens)
