Need a Test Bench
Hey guys, I need to help. I'm looking for a good test bench. The only one I can find anywhere is that silly Lian-Li bench and I don't want it. I'm not a huge fan of using the mobo box as one either so please don't suggest it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811353002
http://www.newegg.com/Product/Product.aspx?Item=N82E16811353001
the silly one?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112287
Yeah that would be the one. I mean it has some good features but it just seems kind of overkill and I'm not really willing to spend $90 on a test bench. But they others you posted seem alright. Are these the only ones your are aware of?
all the ones on newegg anyway I searched through all 600 something cases
