Need a solid Headset for working in the IT call center
So, I just started at the IT department for Lowe's Hardware and I was told I can use my own headset, keyboard, and mouse for work!
Right now I know for sure I need either a G600 or Naga because of all the macro keys I need; copy and paste, passwords, etc. currently leaning towards G600 because it restores to default when windows is locked. However I'm trying to decide on a good cubicle friendly mechanical keyboard and headset.
I need the headset to be:
- Closed Back
- Killer Audio (Mic since I'm taking calls, and Speakers)
- Good noise isolation so I can hear my callers over my coworkers.
- Under $200 US (would prefer $150) budget
I use a software phone for my calls so basically any headset could work, hell I could hook Studio Monitors to my pc and use a table mic for all the software cares.
I would prefer you post headsets you've used and can personally vouch for, but any recommendations will be appreciated.
Thanks!
Towards the cheaper end of the scale, I use Logitech H800's for pretty much the same thing, ie a helpdesk type role with a soft phone.  I also use them paired to my mobile phone while I'm driving.  I probably look like a retard but I can hear people clearly at 110km/h on the highway and they can barely tell I'm driving.
I also use a logitech G510 keyboard to do the same thing you're describing for your mouse, quick save macros for passwords or common network addresses etc.
