I have a FX-8350 and was wondering what a really good/quiet cpu heatsink would be. I don't plan to overclock or tweak stuff. I do heaps of gaming.
A Xigmatek Gaia or Cooler master 212+/EVO whatever you can find cheapest, you can plug it in the 4pin and it should down spin it to temps but I don't imagine you'd need more than 75% fan speed maybe even 50% if you want to set it manually
Agreed, if you are not overclocking, cm evo is a solid solution and there will probably be some case fan way louder than it.
