I've had the Corsair 500r for some time but I want to replace it with either the Switch 810 or the Phantom 630. Whic one would be better in te long run.
Hey when you get a new case, can I have your old one ? And you should get what ever you want. Thanks.
The Switch 810 is a fantastic case; I would go with it.
I think the phantom 630 is a better choice it has amazing air flow.
I was thinking of the 630 too. Better hdd configuration and the 200mm fan options. It's more $ though.
