Need a motherboard suggestion and a cpu suggestion that will fit inside the bitFenix prodigy mini-itx case. The total must be under $265 (or a bit above I don't mind). I must also be able to buy it from https://www.pccasegear.com.
Sorry to say but the best way to get in that price range would be to get a micro-itx FM2+ board and then to get a new AMD kaverari series part in 2 weeks. But that site doesn't have a micro-itx FM2+ board so the only thing you can do is get a intel z87 board with a I3... I'd recommend either stretching you budget and getting an I5 or buying a higher end itx board with the I3, and then upgrading to an I5 later. If you do go I3 you will be handicapped in any modern game sadly...
*sigh* thanks for trying ill just have settle with the atx build :(
