Need a little help with Port Triggering
Hello I need help transfering this configuration to my router.
How do I tranfer this config:
Settings
To this:
sdfcdcs
I think it should be like this but im not sure
Service Type: TCP/UDP
Trigger port from: 3216
Trigger port to: 3216
Starting Port: 37005
Starting Port: 37015
That looks right.
The terms “from” and “to” here refer to the port range, so all ports between those two numbers will be valid for triggering.
Because you only want one port to trigger, make the “Trigger port from” and “Trigger port to” the same.
