Need a little help finalizing 800$ build for my younger bro
HI
I WAS LOOKING TO GIFT MY YOUNGER BRO A GAMING PC FOR HIS 16TH  BIRTHDAY!! MY BUDGET IS 800$ AND WAS CONFUSED BETWEEN TWO BUILDS THAT I COOKED UP. IT WOULD BE REALLY HELPFUL IF U GUYS WOULD TAKE A LOOK AT THE LINK AND TELL ME WHICH RIG WOULD BE BETTER AND IF I SHOULD MAKE ANY CHANGES WHILE STAYING IN THE SAME PRICE RANGE!!!
http://pcpartpicker.com/user/jeffgv940/saved/#savedbuild_771973
THANKS A LOT!!!
EVERY INPUT WILL BE VERY MUCH APPRECIATED AS THIS IS MY FIRST BUILD !!!
I would go this way: http://pcpartpicker.com/p/2sQDJ the graphics card in this is 2x faster than the 270x in your build. But the best feedback i can give, the caps lock button is not mandatory for forum posts.
That build is good, but if you can wait for the R9 280X's to come back in stock at around the same price as the GTX 770, i would prefer to grab one of those, just to make th build a bit momre future proof, since the 280X has a bigger frame buffer ( 3 BG)
