Need a good TV for media and console use
Hey guys, I am looking for a good TV within a $800 budget.
This will be for a third monitor (for mostly media purposes) for my computer, as well as the main screen for my game consoles. Will be almost exclusively used for movies or console games, but I still want it to be able to function as a computer monitor. This will be mounted above my current two monitors, ~ 40in off the ground. My other two monitors are 27in and 24in, 24in to be upgraded here soon as well. There is no height restriction, and it can be mounted very easily with everything fitting at a nice height under it, so this isn't a problem.
Really, the only thing I'm worried about is getting a real 1080p resolution, that will be able to match up decently with my other two 1080p monitors and doesn't stretch the picture, or anything weird. It also needs to have very low input lag, so as to not disrupt me any if I do choose to play a PC game on it, sitting back on the couch.
The real concern here is I need a very small amount of input lag. Can anyone recommend a good TV that has very little? Looking for something at least 40in as well, anything from 40in-60in is good, as it's going to be mostly viewed from ~8ft away.
