Need a Glorious Netbook for under 200 Pounds (340$)
I've been tasked with finding a Laptop for under 200 pounds for my brother. It would be good if it could play games (Minecraft) and maybe some better ones on low. Thanks!
Yeah I would but I'm not sure how good Pentium/Celeron Integrated Graphics are. Ideally it would be i3/i5 but I'm not 100% sure on these things!
This looks Really nice:
http://www.ebay.co.uk/itm/HP-Probook-6560B-Intel-i3-2-1GHz-Dual-Core-8GB-RAM-320GB-HDD-WIFI-DVD-WIN-7-Pro-/181386628524?pt=UK_Computing_Laptops_EH&hash=item2a3b7c4dac
You should look into getting a Chromebook. The c720 from Acer has a Haswell Celeron and can even play Skyrim (at a reduced framerate).
You're gonna want to set up Crouton which allows you to run ChromeOS and a Linux distro simultaneously. Then you can install Steam for Linux and PlayOnLinux which will help him play games.
