Need a device to auto-switch USB cold storage backups
I can’t count on my clients to reliably swap the backup drives on a weekly basis. Is there a device that I can plug both external drives into and then it automatically turns one on and the other off on a weekly schedule?
Smart plugs could work with backup drives that use external power. And then setup automations in Google Home. Not as elegant of a solution as I was hoping for though. And a lot of my clients use the WD Passports that don’t use a power adapter.
while the passports themselves do not use power adapters. you could plug them into powered USB hubs and the hub could be plugged into smart outlets.
If you’re in Windows, I wonder if either of these articles will help.
Mount/Dismount in Script
Alternate Article
