i am looking for a computer case with a side panell window and overall a great looking case. i was really considering the Raidmax tornado in blue because i really like the use of blue leds and the cool design on the side panel. my budget is around $50-$65 (USD). i looked at fractal designs, but they look to plain to me. any help would be greatly appreciated. thank you for your time
This case is normally $100 and easily worth $150, but Newegg currently has it for only $70! Highly recommend it, I have one myself. Lots of room for cable management, high quality rubber grommets, lots of airflow with up to 7 140mm fans, support for 2 240mm thick radiators in push-pull, removable and rotatable hard drive cages, and lots of dust filters. Awesome case!
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352031&Tpk=fractal%20arc%20midi%20r2
If this case isn't on sale when you decide to buy, or you don't like the idea of spending $70 (trust me the Arc Midi R2 is worth it) then the NZXT Source 210 is your next best choice. It supports 2 120mm fans in the front and 1 in the back, 2 140mm fans on top, pretty good cable management, roomy enough for large GPUs, and an overall clean look. It doesn't have radiator support up top unfortunately, but you can drill holes if you really need that feature.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146102
Coolermaster K380 or K350! Great cases!
had the cougar arcon black. great case IMO. When i got it was only 30. even at 50 its a good deal.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811553013&Tpk=cougar%20archon%20black
Not sure if this is also to plain for you too?
