But at any rate, I need a good capture device to record game play footage from my 360. I'm currently using an HDMI to DVI cable from my 360 to a 24" monitor, and I'm sending optical audio to my surround receiver--which is the problem. Anything I can find only has composite video or S-video in, and usually no optical in or out.
Any recommendations on a good device that will--preferably--let me keep my video and audio set up?
Using a dazzle doesn't work in my situation. I play my 360 on a computer monitor with only VGA and DVI inputs. While I could just connect the 360 to the dazzle and then view the input on my computer, there's too much lag in the signal (at least with a dazzle). I need something that would allow me to record the signal whilst sending it to my monitor. I've been looking at the HD PVR, but once again I wouldn't be able to connect the signal to my monitor--unless there's an HD component to DVI routing method I'm unaware of.
Google yielded no positive results about this topic when I searched. I might pick up an HD PVR (heard a lot of good things) and see if I can find a reliable component to DVI cable/converter or a video splitter to send the signal to my monitor.
I could play on my TV, but I play competitively (tournaments) and it's just easier to scan 24" than it is to scan 42".
Prawn, do you know what model of Hava your friend uses? Last I heard they had a handful of models and some of them were crap.
