Need 144hz monitor help
AOC G2460PQU 144Hz
Asus VG248QE 144Hz
BenQ XL2420Z 144Hz
Philips 242G5DJEB 144Hz
Can I please get the Pros and Cons of each, and which one is the best?
I have the Asus one, and like it, to be honest if I could do it again I would just got IPS 60hz. The picture quality isnt bad on the Asus one and  you adjust it to look good,but I know it could look a lot better. There is not "Best" everyone has their preference and has certain things they want. For example if you want to run Gsync the Asus one would be the way to go(addon mod / they have a gysnc model if I am not mistaken). That doesn't make it the best though. I would try and see as many as possible in person or somewhere that has a good exchange.
Tbh none of them. I know some people will yell at me for this but really IMO AMD having used them all there is no reason to get something higher than 60HZ.
I know some people are more sensitive and claim that any serious player needs the higher refresh rate but I'm calling BS on that.
I'd rather have a nice 60HZ IPS panel over a 144HZ TN unit any day.
Plus your GPU won't be able to drive really any game that fast so it is sorta pointless.
I'd rather drop $280 on a faster GPU and more RAM in your case than a monitor.
+1.
144hz is for the epeen factor imho, have a look in person the difference between 144hz tn panels, 60hz tn panels and an IPS panel.
