Need 10G network card drivers
I have a 10G network card that has a device ID of PCI\VEN_1924&DEV_0813&CC_0200 and I need drivers for it. I tried searching it, but got “Your search - “PCI\VEN_1924&DEV_0813&CC_0200” - did not match any documents.”
Is it a motherboard nic? Add in card?
Add in card. I found this page which appears to have working drivers for XP+ (Although 2008/Vista is the minimum listed, there is a XP/2003 folder in the installer). Installed them under 7, and the card appears to work. Will try XP next since this PC has it lol.
Edit: yes lol
