First off let me start by saying thank you to anyone who takes the time to read this and second I AM A FIRST TIME PC BUILDER. There are several reasons I am building a PC. First off, I am starting to partially stray away from Console Gaminng so I want to make sure this Build is good for gaming. Second, I love doing work in Photoshop, and Cinema 4D. I also have a YouTube Channel (http://goo.gl/Pm1zg) which requires editing videos in Sony Vegas. So I need to make sure this is not only good for gaming but also a monster video editor. I have around a $1500 budget however if there is a necessary part that you may think is essential then I am willing to go over a little but I would prefer not to. Would you please reccomend parts please for my Video Editing and Gaming Machine. Thanks!
I'm gonna tweak what Brennan did because you want to do editing. AMD is king for editing thanks to OpenCL. This is a new development because the older versions of Premiere did not support AMD graphics cards. So, here is what I'd do:
CPU: Intel i7 4770k:http://amzn.to/11QbyDc - Overclocking is insanely easy. It's worth the extra loot even if you only barely OC.
Motherboard: ASUS Z87 Pro - http://amzn.to/12uilmn This one has wi-fi built in and all the other options that you need
Hard Drive: http://amzn.to/16VNgR7 - The one you picked is a great price
Storage Drive: http://amzn.to/19GW4rS (you will want more in the future as well)
RAM: 16 GB of 1866 Corsair RAM - http://amzn.to/17nlIkp
GPU - 7970: http://amzn.to/123h7P4 - This one is so cheap right now that it is an instabuy before they run out.
That depends on what software he usus for editing; he may be using CUDA-optimized, not just CUDA-supporting, software, such as the Adobe Suite, but if he is using Sony Vegas, for example, he is much better off with an AMD GPU. OpenCL itself is a much stronger architecture, but CUDA optimized programs can be very competitive.
I would stick with the Lepa G 650 PSU, though, for the added efficiency of the lower wattage, low ripple, and semi-modularity (24 pin and EPS.)
