NAS Build
So I'm trying to build a NAS because my 1TB portable is about full of backups and I don't want to buy any more portable HDD's. I have a power supply and case already from a old Lenovo P.O.S. and just need to know if these parts will work for one.
Motherboard:
Gigabyte GA-H87M-D3H (This I'm really open on but my only thing is it has to have SATAIII ports capable of RAID without having a separate RAID card.)
http://www.amazon.com/Gigabyte-Intel-6Gbps-Motherboards-GA-H87M-D3H/dp/B00DGHDQVO/ref=sr_1_16?s=pc&ie=UTF8&qid=1387810762&sr=1-16
CPU:
Intel Pentium G3220 Dual core at 3.0ghz
http://www.amazon.com/Intel-Pentium-Processor-G3220-BX80646G3220/dp/B00EUVG3P6/ref=sr_1_3?s=pc&ie=UTF8&qid=1387810777&sr=1-3
RAM:
Crucial 4GB DDR3 1333
http://www.amazon.com/Crucial-PC3-10600-Unbuffered-240-Pin-CT2KIT25664BA1339/dp/B001R4BT1M/ref=sr_1_9?s=pc&ie=UTF8&qid=1387811209&sr=1-9
HDD's:
Western Digital 4TB RED (x4 in RAID 5 witch if my memory is correct should give me 8TB of usable storage and have all data mirrored in the array.)
http://www.amazon.com/Western-Digital-Cache-Drive-WD40EFRX/dp/B00EHBERSE/ref=lp_1254762011_1_5?s=pc&ie=UTF8&qid=1387812151&sr=1-5
Those parts will work fine for a NAS build, it could be worth getting a NIC with more than one ethernet attached if you want faster transfer rates (only if you have large amounts of systems that will be connecting at once) - sometimes 1Gb just ain't enough ;) Other than that it looks great. You going to be installing freenas?
4x 4TB in RAID 5 will give 12TB of storage.
However I really do advice against using on board RAID solutions for anything other than RAID 0 or 1. RAID 5 is quite compute intensive and with most on board solutions will render terrible performance.
Also I advice against on board RAID solutions, as if the board fails. So will the RAID and there is slim chance of recovery providing you get an identical controller on the same chipset board.
You could run RAID 10 of an on-board solution just fine (2 disks strip, whilst the other 2 mirror the first) this will result in 8TB of storage but better overall performance.
As for your other components, they are perfectly suitable for a NAS running RAID 0, 1 or no RAID at all.
Other solutions to fail over within storage (with out using a RAID card) would be to look at ZFS or unRAID. However these require much faster CPUs and more RAM to aid in computations and disk write speeds.
Yeah I'll be using freenas, and as far as the NIC goes it should be fine, most the data from it to other devices will be done over wireless N (phones, laptops, etc) except to my console witch I might try to set up a media server to stream my music and a movie to once in a blue moon but that would be all.
Thanks for the info, I guess I'll be going with RAID 10. I would use a dedicated RAID card but I'm trying keep it on the low cost side.
If you're streaming media over more than a couple of devices in HD, it could get a bit choppy.. Also a great media streamer is Plex, you can install the server on freenas and there are clients for Android, iOS (and DLNA) etc and it can transcode into lower bit rates if need be..
