Hello,
I’m looking to build a NAS, with the W680 chipset, specifically, this micro-ATX board: Pro WS W680M-ACE SE - Tech Specs|Motherboards|ASUS Global
My needs are:
- 8x Sata HDDs
- 4x M2 NVme SSDs
- 10GBase-T
Looking at the motherboard I have:
- 2 x M2 NVme slots
- 4 x SATA 6Gb/s ports
- 1 x SlimSAS Slot Support SlimSAS NVMe device (supports PCIe 4.0 x4 mode and up to 4 SATA devices)
- 1 x PCIe 5.0 x16 slot
- 1 x PCIe 4.0 x4 slot
- 1 x PCIe 3.0 x1 slot
Since I don’t need a graphics card, my idea was to use the x16 slot for an Asus Hyper M.2 x16 Card, giving me 4 extra NVmes. However, I’ve realized that the motherboard does not support bifurcation, and therefore if I’m reading this correctly: [Motherboard] Compatibility of PCIE bifurcation between Hyper M.2 series Cards and Add-On Graphic Cards | Official Support | ASUS Global I could only fit one Nvme on that card? Which seems like a waste of an x16 port.
Instead, now I’m thinking, I can use the PCIe x4 slot for one NVme, and the SlimSAS Slot for one NVme, giving me the four total I need. That leaves the x1 slot for 4 more Sata ports using this card: Amazon.com and the x16 slot for a 10GBase-T card.
Please, let me know if I got anything wrong.
My exact questions are the following:
From the PCI-E x4 port, what exact adapter do I need, and can you recommend a specific one to use it a connect an M2 NVme?
From the SlimSAS slot, what exact adapter do I need, and can you recommend a specific one to use it a connect an M2 NVme?
Given that I have a whole x16 slot for the 10GBase-T now, I am picking between the Intel X540 and the Intel X550. The X540 costs half, and uses x8, while the X550 uses x4. Is there any reason to pay more for the X550?
For the Intel cards, since it seems very difficult to get real Intel ones, is 10GTek a solid brand for them?
Thanks for reading!
