I have long been debating what to do for a NAS. In the past I was debating a Synology vs Asustor box, but always find a reason not to go forward with it (price, security, expansion, apps). I now have begun to think about building my own again, but am overwhelmed with the idea of the software side of it. My current system is beginning to show signs of age and I would like something a little more purpose-built with room for expansion.
The current system I am using as a pseudo-NAS, specs listed below, is in a small form factor Dell Optiplex with NO ROOM FOR EXPANSION. I currently have ZERO redundancy and would like to change that.
The primary purpose of this system over the past couple of years has been to host my Plex server, which may end up being Jellyfin, but that is another discussion. It also has hosted games servers such as Ark, Minecraft, Valheim, etc.
While I do not have a specific budget in mind, I am open to cost-effective solutions, and understand that drives are an additional cost that are sometimes considered separately from the rest of the build. Ideally I would like something in the range of a Node 804 to ATX form factor, so that I can have multiple drives down the road. Otherwise, I am open to suggestions.
In regards to software, this is where I often become overwhelmed. I want something that is simple enough that I can learn it without needing too much assistance. I fully understand though that I as time goes on I will become more adept at using it. I know that TrueNAS and FreeNAS have a lot of documentation and support out there, which would be potential solutions, but I would be open to other suggestions as well.
EDIT: I totally forgot about UnRaid, but that also seems to be a good entry-ish level option. Plus it seems to have decent plugins for media centers.
This will be largely be an “in-house” server only. However, I would not be opposed to being able to access it from outside of my network, but if the security and privacy of the server takes a big hit when I do this, then I can live without it. Any use outside of the network 99% of the time would be streaming media from Plex or simply accessing office suite files.
I have been thinking that, to start, 12-16TB would be a good amount of storage, but I would like it to be expandable moving forward without too much of a hassle.
Current “NAS” specs
-Intel i5 2400
-12GB DDR3 non-ECC
-Dell Optiplex
-240GB SSD boot drive
-6TB WD Red storage drive
Any guidance or wisdom would be appreciated it! I am still researching some options so I may return with some updates of where I am at.
