I've decided against doing my x99 build for now. Instead I decided to focus on doing a NAS Build instead. I'll be installing FreeNAS on it. I'll be using it to store my video footage while I edit the footage, and various other things I work on.
PCPartPicker part list: http://pcpartpicker.com/p/r9h7dC
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor ($249.99 @ Amazon)
CPU Cooler: Corsair H50 57.0 CFM Liquid CPU Cooler ($49.98 @ OutletPC)
Motherboard: Gigabyte GA-H97N-WIFI Mini ITX LGA1150 Motherboard ($113.99 @ SuperBiiz)
Memory: G.Skill NS Series 8GB (2 x 4GB) DDR3-1600 Memory ($63.98 @ Newegg)
Storage: Western Digital Red 2TB 3.5" 5400RPM Internal Hard Drive ($94.99 @ SuperBiiz)
Case: Fractal Design Node 304 Mini ITX Tower Case ($78.99 @ SuperBiiz)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply ($29.99 @ Newegg)
Other: Intel PRO/1000 Pt Dual Port Server Adapter ($43.01)
Total: $1199.87
Explaining the build: 12 TB is plenty of space for me. I will not get a hard drive with 3TBs, I had too many of them fail on me. The motherboard supports them. I think the Motherboard comes with 2 intel network adapters but I wasn't 100% so I included one. While I have no intention of overclocking this build, I went with watercooling so that I can have clearance for ram and fit all 6 of the hard drives. I went with a Corsair Power Supply because it was cheap and I know SeaSonic makes Corsair so it should be good enough for what I am doing.
Any thoughts on the build? Should I change anything?
