NanoKVM lite ATX Power setup?
I got a NanoKVM lite from a friend who had a couple of extras (its not the full version that comes with the ATX module and OLED screen). I’m a bit confused about how to connect the KVM to ATX power.
Do I just connect the PWR+ on the motherboard to PWR pin on the KVM (the one that says GPIOA 23). What about PWR- on the motherboard, does it go to ground on the KVM?
So does this mean that I won’t be able to use the Power and Reset buttons on the case anymore?
Additionally I had one more question about KVMs in general, will connecting a KVM use up GPU memory and GPU cycles? Ideally I would like my GPU to idle and consume as little power as possible, except for when I’m actively using it for some ML work.
