I just want to make sure I understand the documentation and examples I read online correctly in making my little database.
My goal is to have rows in the the switchrolevlan table delete when a row in the switch table is deleted that is referenced by the switchrolevlan row (same goes for the node table and the noderoleassign table). I’m worried that I may have the SQL code backwards. Also, I have never made use of FORIEGN KEY before, so I may have the syntax regarding that incorrect as well.
CREATE DATABASE pffailover;
USE DATABASE pffailover;
CREATE TABLE role(
role_id SMALLINT NOT NULL UNIQUE PRIMARY KEY,
name TINYTEXT NOT NULL,
notes TEXT,
CREATE TABLE switch(
switch_id varchar(50) NOT NULL UNIQUE PRIMARY KEY,
type TINYTEXT,
description TEXT,
CREATE TABLE switchrolevlan(
switch_id varchar(50) NOT NULL FOREIGN KEY,
role_id SMALLINT NOT NULL,
vlanNum SMALLINT NOT NULL,
FOREIGN KEY (role_id)
REFERENCES role (role_id)
ON DELETE CASCADE
FOREIGN KEY (switch_id)
REFERENCES switch (switch_id)
ON DELETE CASCADE
CREATE TABLE node(
mac varchar(18) NOT NULL PRIMARY KEY,
reg BOOLEAN NOT NULL DEFAULT FALSE,
voip BOOLEAN NOT NULL DEFAULT FALSE,
CREATE TABLE noderoleassign(
mac varchar(18) NOT NULL FOREIGN KEY,
role_id SMALLINT NOT NULL FOREIGN KEY,
FOREIGN KEY (mac)
REFERENCES node (mac)
ON DELETE CASCADE
ON DELETE CASCADE
