My x-99 plan bluild (Gillespie GO2)
Khristian Gillespie
Final PC update
Gillespie GP02 Intel & AMD Build
(2/2/2016)
PCPartPicker part list: http://pcpartpicker.com/p/Gnh8nQ
Price breakdown by merchant: http://pcpartpicker.com/p/Gnh8nQ/by_merchant/
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler ($89.94 @ Amazon)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($157.99 @ Newegg)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($99.99 @ Newegg)
Case: Fractal Design Define R5 (Black) ATX Mid Tower Case ($109.99 @ NCIX US)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply ($163.99 @ SuperBiiz)
Optical Drive: Asus BW-16D1HT Blu-Ray/DVD/CD Writer ($81.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Pro OEM (64-bit) ($124.78 @ B&H)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter ($36.95 @ Amazon)
Case Fan: Noctua NF-A14 industrialPPC-3000 PWM 158.5 CFM 140mm Fan ($27.20 @ Amazon)
Other: AMH 399U 39" UHD Real 4K LED Monitor 60Hz ($677.00)
Other: AD FirePro W7100 Graphics Workstation ($619.99)
Other: ASUS X99-DELUXE/U3.1 LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.1 ATX Intel Motherboard ($399.99)
Other: Intel Core i7-5820K Haswell-E 6-Core 3.3 GHz LGA 2011-v3 140W BX80648I75820K Desktop Processor ($384.99)
Other: G.SKILL TridentZ Series 16GB (4 x 4GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z170 Platform / Intel X99 Platform Desktop Memory Model F4-3200C16Q-16GTZB ($124.99)
Other: MSI Radeon R9 390 Gaming 8G ($329.99)
Total: $3684.15
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-02-02 11:11 EST-0500
What are you using your PC for?
Also those 3TB drives are going to die and die quickly, you're also spending a bit too much on fans
I don't see anything wrong with your list, but are you sure you want those fans? They push a lot of air, but they will be very, very loud.
Which fan's you know that match noctua spec's in air flow and noise level then?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103052
120mm fan 4 packs are usually the thing to get, why would you possibly need that much air flow? Otherwise the Venturi Fans from fractal are rather nice, bit less airflow, but a bit less noise naturally, and you can turn them into 120mm fans as an option
http://www.newegg.com/Product/Product.aspx?Item=N82E16835352023
Thank you very much sharing the venturi fan link.
Jays has a video on them
And I'm partial to the HR-22 myself, it's just such a ridiculous cooler, pair it with the High Pressure Venturi fans and you're set for up to like 300W TDPs
https://pcpartpicker.com/part/thermalright-cpu-cooler-hr22
Good build, not realy have much to add to it.
Thanks. I just need get prats now.
Using for gaming, editing and creative projects like SFM,/ Garry mod and illustration work.
and like why the super fast RAM? You could double your capacity unless for some reason you need the speed
32gb $139
https://pcpartpicker.com/part/gskill-memory-f42133c15q32gnt
Also like seriously, change those drives, seagate is in the middle of a class action lawsuit over their 3TB hard drive failure rates, I doubt it'll actually go anywhere though.
and don't get an OEM windows thing, you can only use it once
I need check for DDRR 4 (32 GB) ram for my X-99 build.
The compatibility filter is screwed up, it shouldn't have had DDR3 avalible for a 5820K
in any case $139 DDR4 32GB kit
