Extras: Bitfenix Specter Pro 200mm Red LED, Phanteks add-on pump bracket for the Enthoo Pro, Bitfenix Alchemy Braided Extentions Black for 24-pin, 8-pin EPS, and 2x6-pin PCI-e
Watercooling Components:
CPU Block: PPCS Custom Swiftech Apogee XL ROG Edition
Radiator: Swiftech MCR320-XP 360mm Radiator
Reservoir: Phobya Balancer 150mm Matte Black
Pump: Swiftech MCP655 w/ speed control knob
Rad Fans: EK Vardar F4 2200RPM
Tubing: Primochill Advanced LRT Bloodshed Red 1/2" ID x 3/4" OD
Anti-microbial solution: Monsoon Silver Bullet
Fittings: XSPC 1/2" Barbs Black Chrome x4, Alphacool 1/2" x 3/4" right compression fitting x2, Enzotech G1/4" extension, Monsoon G1/4" stop plugs x2
Coolant: Steam distilled water
Other: XSPC 360mm Radiator Gasket
So that is my parts list, pictures will be coming soon
First lets talk about the Bitfenix Specter Pro in the Enthoo Pro (and Enthoo Luxe because the Luxe shares the same chassis as the Pro). The Spectre Pro will NOT natively fit in the Enthoo Pro without doing a mod to the frame.
The mod is on one of the corners of the fan you need to remove some of the plastic in order to make it fit. Here are picture of the modifications that need to be made:
Also I used the reservoir mounting accessory that was included with the case to mount the reservoir.
[A quick aside: I did need to mod the reservoir mounting plate due to conflicts with the corner of the graphics card, I need to drill 2 holes to the side of the included and tapped holes in order to fix the conflict. This conflict should not be a problem if you are using a card that is less than 250mm and/or a reservoir with mounting clips that are shorter than the standard ones that come with Aquatuning reservoirs. Also this reservoir came with nickel plated stop plugs, make sure if you buy the Balancer to get non-nickel plugs with it if you plan on using silver as your biocide]
Here is the radiator mounted to the top of the frame with Yate Loon fans that I was previously going to use before I got the EK Vardars (also the Enthoo Pro uses phillips head screws on several of its parts of the frame so I am able to take the top panel of the case off to attach the radiator to it :D)
Also for a little information on the Pro/Luxe frame: the maximum clearance for the top mounts is 65mm which on the Pro when using 25mm fans gives you a maximum radiator thickness of 40mm while on the Luxe fans 25mm fans can be mounted above the frame giving you a maximum radiator thickness of 60mm
And here is a picture of the completed internals, filled, bled, and POST-ing (also if you look carefully in the lower left hand corner you might catch a glimpse of the idle temperature :3 )
