My system
I think i have pretty much finished planning out my system so if you guys could tell me what you think that would be great!
It is a silent workstation/gaming build and here are the parts:
i7 4790k
asus strix 970 gpu
asus z97 pro gaming motherboard
corsair vengence 2133mhz 16gb ram
fractal design R5 case
intel 730 ssd and wd black 1tb hdd
Seasonic SS-520FL2 fanless 520 watt power supply
asus pb238q monitor
4x 140mm cougar vortex fans
noctua NHU-14S heatsink
logitech g710 plus keyboard
roccat kava plus mouse
windows 8.1 64 bit
yeah there it is so if you guys could tell me what you think that would be great!
Thank you!
Sounds like a nice build. Those seasonic fanless psu's are very nice. There are some reports of coil whine with those. My ear's aren't quite sensitive enough but if you get close enough to the psu you can pick it up.
nice build.
not bad, are you doing some editing/rendering im assuming>?
Good build, everything looks good, however if you want some more opinions, then you should show what price you want to get and we might be able to help you more.
My budget is about 2000 to 2500
I will be using it for pretty heavy workloads and gaming.
That kinda budget + heavy workloads I'd be looking at a X99 setup.
do you think? will and X97 build be sufficient enough to be able to run multiple programs at the same time?
Its just a big budget you have.
This is a $2.5k system
http://pcpartpicker.com/p/4pwW8d
