My small business server location
Hello, I am starting a new small business which I will be providing a middleman platform between roughly 10,000 customers to start off. All of the customers will access my platform to see what other customers have for sale and will purchase or sell on my platform(this is a very broad overview). I am hoping to find suggestions as to where I should host my platform. I am leaning toward buying racks to install in a data center. I will be allowing access to my platform via a mobile app and website so I know that this would most likely reqiure at least one server for the app and one for the website/platform. My background is in coding so I went thru general network/server classes during my Computer Science Degree years ago. I hope that I can find some suggestions as to where I might start when it comes to building/installing/and location of the hardware. thanks
Given you’re a startup, consider co-locating for the time being. A full rack is seriously expensive, co-lo is a viable cheaper option. You can hire a server or build one yourself, just make sure if you take the latter route said server needs to conform to the spec’s of the data centre to allow co-location. Your chosen host will be able to provide you with their specs for servers.
Thanks, I should’ve specified that I was talking about, just co-locating and just buying one or two servers to put into rental slots in the data center.
With one or two servers you are on very thin ice. Ask yourself if something goes wrong and you get an outage for a day can your business survive that?
Maybe look into VPS instead, or at least as a backup you can spin up on demand.
tbh i would just use cloudflare ovh or something similar till the business is up, running and profitable.
amazon lets kick exist alongside twitch…
so i see no reason you couldnt launch your marketplace using there hardware.
it will be way lighter on your wallet. (go look at puget to see the cost of just a small 32 core, 128gig single slot rack mount :sob: )
once you know you have a marketplace people want to use, consider adding hardware at a datacentre.
To add to all other insightful comments, do not underestimate the amount of work needed to secure a ‘couple’ of servers.
A lot of the cost comparisons I see between self-hosted and cloud do not take that into account.
If you are serving a web app to tens of thousands of users, you need to account for things like authentication/authorization, having proper backups, resiliency, eventually load balancing and distributing your load across servers during spikes in the workload.
You can do it when self hosted but the cost of initial deployment and maintenance will skyrocket well past the base cloud offerings
thank you all
Given your background in coding, you’ve got a solid foundation. For hosting, renting server space in a data center might be a good move, especially if you’re expecting a good amount of traffic from those 10,000 customers. It’ll give you control over your hardware without the headaches of managing it all on your own.Consider cloud hosting, too. It can be super flexible, allowing you to scale easily as you grow. When I was building a platform, I opted for a hybrid solution with both on-premise servers for sensitive data and cloud services for scalability. It worked well!Also, check out germany.houseofcompanies.io. They offer some great tips for businesses expanding, especially if you think about scaling into new markets.
