I posted about two months ago and got some responses for a potential build for playing games on ultra, specifically open world games on 1080p.
I researched the parts and looked at their alternatives and saw their prices/benchmarks and etc.
My original build was proposed by DrunkenPanda (thanks for taking your time) -
http://uk.pcpartpicker.com/p/38KbC
And after all my research and etc I came up with - http://uk.pcpartpicker.com/p/3tXRd I have bought two parts of the build SSD & RAM due to the price being cheap
- I picked 8320 due it being good for value. Also I decided against 8350 because I can overclock 8320 to 8350. Would this be okay for Watch Dogs on the new released requirements for Ultra?
- > http://www.inferse.com/14471/watch-dogs-jonathan-confirms-ultra-specifications-pc/ - Watch Dogs Specs stating 8350 is recommended
- I stuck with the cooler
- I picked Asus M5A99FX PRO R2.0 because from what I have gathered it is good for OC'ing
- I bought the Kingston ram because it was cheap
- I bought the SSD for 79.99 and it's a larger size than the previous one which was suggested.
- I picked the R9 290 Tri-X because it seems to be one of the best versions of the series, and it was below 350.
- I chose the case because I want to see the pretty build
- PSU is obvious.
My questions are as follow, will the 8320 be sufficient for Watch Dogs if I OC it to a 8350. I will be hoping to do this anyway because if I can save money and get it to that level it's worth it. I don't want to over do it. I just want the same speeds/settings as 8350 is possible. Nothing crazy or unstable.
Is the M5A99FX Pro better than the GA-990FXA-UD3 Rev 4.0? I really like the on/off charge feature. HOWEVER I also like the fast boot up on the M5A99FX. But if isn't worth it overall I would be fine with that. I want what is best for the rest of the system, so that would be CPU and GPU.
And finally, is everything compatible? I know I will have to remove the trays to fit the GPU in due to it's size but rest I think is ok. If there is any mistake or a problem let me know :D
