I think I have my first gaming PC planned out, but I just wanted to run it by some experts before I bought the parts. So, click here: http://pcpartpicker.com/p/19Sym for the part list.
P.S. I will be getting two case fans, and they will both be for the radiator.
EDIT: I have updated my design based on your suggestions. Please check that for more feedback.
looks good. Bear in mind that the R4 is designed for 140mm fans not 120 - the 120's will fit but you need to use screws and cant use their toolless fan mounts.
Your radiator will come with 2 fans on it but I dont think you will have clearance for the H100i to mount it in the top of the case. I have an R4 and I cant fit a rad in the top - you can it it in the front but you will have to swap out the fan tray and move the HDD cage back.
if you want to see the clearance issues i can take a few photos of my case and get them to you via facebook or skype (on skype i can give you a guided tour :P)
Plenty of people would recommend the H100i. However, I am running the same chip, and I manage to keep it cool with a Phanteks 12DX, for about half the price. Runs quieter than the H100i. Contrary to popular belief, all-in-one coolers don't deliver the best thermal performance.
I think a custom cooling loop is the only liquid cooling that is worth installing. That's just my personal opinion. Other than that, you've got some pretty good components here. I'd recommend a bigger SSD, if you can afford it. 120GB will get eaten up pretty quickly.
The 770 will give great performance for the price on games that are coming out in the near future... Though i would get a 4gb model. Games will use more than 2gb vram in 2015, and maybe 2014.. if you plan on keeping the card longer than two years, consider the 4gb model.
Also, if the noctua fan is for the radiator, then you want to get two of them, and I would recommend 1 more fractal design case fan (140mm) for the front of the case... Maximize the airflow.
I'd suggest adding a large mechanical hard drive to store games on. That 120GB SSD will fill up real quick if you install a few games on it. In my system, I use a SSD for Windows, documents, and regular programs, all my game installs go to my HDD.
I will be getting two noctua fans, as I said in my post. The only reason it lists one is because pcpartpicker glitched out and wouldn't let me add another one. :)
It looks good really man. Just think about getting another 140mm intake fan to give you positive air pressure in the case. If you have too much suction then dust will be pulled into the cracks and small holes of the case. You want to pull in air through the dust fans.
