My pixel 2 XL is broadcasting like a remote control: https://youtu.be/_VpMPfsNBWw
This appears to be continuous (have have not observed it not happening).
Why would this signal be broadcasting?
Did you check to see if it was morse code? That’s half a joke…
Looks more like the proximity sensor which is infrared.
Can confirm, its a prox sensor.
Are you using the active display feature? Try disabling that and see if that stops the proximity sensor from going crazy.
