My phantom 530 front panel is not going on! PLEASE HELP!
my phantom 530 front panel is not going on. please help!!
You need to squeeze those clips together to get them through the hole in the chassis.
Don't trap your fingers.
Check the hole isn't blocked, too.
I really appreciate the response but I tried that and it didn't work :( I really need help man.
you need to be carefull a bit with the front panel.
make sure you alline it perfectly, and then slowly push it back on.
Somethimes it goes easy, other times its a bit harder.
If you are still having trouble with it and assuming the clips are the same as on the H440 I have an idea.
Take the front panel.off and squeeze the offending clip together and then tie it in this shape with some thin string. Then when it is through the hole you can cut it and it will secure.
The NZXT cases from my time taking apart the H440 are really well built and the tolerances are pretty tight. Just requires a bit of patience and a little force.
